35 massey hydrolic pump
Bob2299
New User
I just bought a 1959 35 massey with a 3 cylider, my problem, the tractor was taken appart at the hydrolic pump, the pump was in pieces, i have bought a rebuilt pump, now i need to figure out how it all goes back together, but my question is, do i need to make or buy the gaskets, the one for the big heavy draft control lid, and the one for the round side plate or can i use an atomotive silicone?
I paid 500.00 for the tractor, the engines runs, got it started 2 days ago.
Thank you for any help i may get
Do not use silicone at all around the hydraulic system. It will blow out or get sucked into the system. Buy the proper gaskets.
I usually cut my own gaskets for the round side cover plates and for the two pump locating pins and usually buy the top cover gasket because of its size. I would not use silicone.
Before installing the top cover you should check the adjustment of the quadrant linkages. Easier to do it now than find out it doesn't work right after its installed.
Dan
Yes i have been doing some reading, and I should adjust the quatrand linkage, looks a little complicated, i am trying to find a video that would show how to do this, i found one but it"s from the UK, need a special dvd player.
Thnx for the help guy"s
Also did not know what those 2 forks were called, until i did some reading "quadrant linkage" thnx, i am a license auto body teck, not a mechanic, but i will try anything once, also called my Massey dealer ship to see if they have a gasket kit for this, could not find one on this site! Maybe i am not looking at the right place
While your in there make sure you replace the pressure relief valve if the rebuilt pump didn't come with one,so you don't bust the lift cylinder and cover like so many have from old failing relief valves.
I bought the DVD from the UK. It is really good—has step by step instructions for the 35 hydraulic system.
Should be some way to play the DVD. Some DVD players are 'all region' players or can be converted to play other region DVDs using software. Anything I get from the US has to be played on an 'all region' player.
This site has the top cover gaskets, see link.
It's not to complicated to adjust the linkages but you do have to follow the instructions step by step. Once you do have everything back together don't forget to set your quadrant top stop bolt correctly or the lift will raise to far and that's where something will break if the relief valve doesn't release.
Dan
35 hydraulic parts
I purchased the UK DVD on rebuilding the MF-35 hydraulic pump and it played just fine on the DVD player in my laptop computer. It is an excellent video that takes you through each step with a clear explanations of what to do.
