WAYNE-N-TX
Baled hay this weekend with my new to me MF cab tractor. Everything went fine, was the first time with a monitor. With the engine running normal temperature and RPM's, working speed, there's no problems, engine sounds very good. When I cut the RPM's all the way back to an idle the oil light comes on. Rib the engine up, the light goes out.
Do you think it's an oil pump problem or maybe a censor. Like I said, the engine sounds normal, no clicks, knocks or vibrations.
