MF-240-S Missing Grease ??
FBH44
Decided to really grease the steering post until I could see grease coming out someplace. Put in about 1/2 tube, into that rear grease fitting just below the steering wheel, and don't see anything coming out anywhere. Any ideas? Keep on greasing?
Do not grease anymore, that bearing only requires one pump of the grease gun. Your grease will be making it's way down the tube into the steering box . The steering box will probably be overfull, so keep checking the oil level at the bung as the grease works its way down over the next few weeks. Too much oil mixed with grease in there will possibly blow the seals....the actual oil-grease mix will not do any harm, it is just the quantity that would give me concern.
Sam
