1085 Massey Multi-power
Anonymous-0
Hi
Would someone please give me a cost estimate for have a multi-power rebuilt? It s not out but getting weak when oil gets hot. Are parts available and can the average joe rebuild with a service manual? Thanks
How does the PTO and auxillary hydraulic systems work? If they are weak also the 2 stage hydraulic pump may need replaced if oil pressure and flow drops with hot oil due to internal wear. Does it have a cab, or open station?
I had mine go once - it was the pipe inside had cracked. The biggest part of the job regardless is splitting the tractor-especially if there is a cab.
I just replaced the PTO brake / disk in mine a couple months ago. 70$ part on a 1000 repair... there were a couple other things. Grant
