Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Massey Ferguson 245 lift
MKinON
04-28-2013 12:57:15
If I have it right, 245 is a newer version of a 135. There should be a dipsick at your right heel, sitting on the tractor, in a round cover. Also will be a sliding lever, forward aft, to control lift response rate. One direction or the other will increase the speed of lift drop, for varying it according to implement weight, etc. The knocking is probably worn pins that hold the pump in place in the housing. This allows the pump to "rock" a tiny bit against these locating pins when it's engaged. The sound is prominent when the lift needs to hold a load. Been told it's common in these as they age. Our MF 30 has been doing it for as long as we've had it, 3years. Not sure if it's the pins or the sockets in the pump that would need replacing to cure it. Go to www. agcopartsbooks.com and sign in as a guest to see what it looks like. It's the differential case page you want.
