TractorLinks.com
Show Parts for Model:
Re: MF 135 Hydraulic Draft Control
Vineet
04-25-2013 17:45:46
Hi David,
I did adjusted the control spring like you said and also installed in back the same way you said.
Yes it lifts the plough clear up the ground where only the ferrow wheel was touching. After lifting, it drops it back 1-2 seconds. Can you please advise more on the bent frame.
Actually the pump frame where the control lever is attached, that frame was bent backwards towards the PTO, I have made it straight. Can it be the problem.
The initial problem with the system was that it was keep lifting and making the relief valve sound. Then the valve becomes stiff and we cant move to release. I changed the control valve and spool only. Should I change the O-rings also.
After I did the changes the pump works fine in lifting and maintaining positions. The only problem is that implement come off the ground with I plough.
Do you feel that I should bend the frame of pump (holding the control lever) like it was.
DavidP, South Wales
04-26-2013 01:05:52
 Re: MF 135 Hydraulic Draft Control in reply to Vineet, 04-25-2013 17:45:46
Hi,
The frame that I'm referring to is mounted on the underside of the hydraulic cover. It consists of cam levers running between rollers.
If you look at them you will see that they resemble a dog and a giraffe. You will see a circular shaped framework around the 'giraffe'. These do become bent.
I think that the next step would be to rig up a long bar so that you can simulate the compression force in the top link assembly as if you were ploughing. This way you can easily move from a compression to a tension situation as if the plough were being lifted from the ground. Drain the oil to the level of the bottom bolt on the RH side cover. Remove the cover if not already done. Have an assistant work the bar to activate the DRAFT mechanism. Try it at different positions of the DRAFT lever.
When activated the pump lever will move rearwards to lift the linkage. When the bar pressure is released the linkage should fall. If it continues to rise as appears to be the case then it would appear that something is sticking.
Check the frame rollers for any flats as this can cause problems. As a check on the pump you can move the pump lever by hand very cautiosly to ensure that there is no sticking in the control valve or the lever pivot.
See how you get on with these checks.
DavidP
Vineet
04-26-2013 03:08:51
 Re: MF 135 Hydraulic Draft Control in reply to DavidP, South Wales, 04-26-2013 01:05:52
Thank You David, I will try this in the weekend will let you know.
Can you please advise what book are you referring too. I can see that its more detailed than MF 27. I want to buy that book so looking forward for your help.
DavidP, South Wales
04-26-2013 11:42:45
 Re: MF 135 Hydraulic Draft Control in reply to Vineet, 04-26-2013 03:08:51
The book is the UK/European workshop manual for the upgraded 135. It was published about 1972 and is publication number 1856 027 M1.
Cheers
David
