TractorLinks.com
Show Parts for Model:
Re: massey ferguson 2200 wont go
chuck41
04-25-2013 13:25:29
Sounds as if your main drive"shear" coupler has
broken. To check look in the left round cover of
the diff. hsg. You will need to drain a bit of
oil or tilt the tractor so that left side is a bit higher. The coupler has a grooved ring that
will shear. If so simply align the coupler with
the front short piece of shaft and the pair will
come out easily.No need to split.The trans fluid
is seperate and the check-fill plug is right in
the gap between the running board and the housing
and I can't remember which side. Your manual will
show. Chuck
makin' hay
04-25-2013 18:58:22
 Re: massey ferguson 2200 wont go in reply to chuck41, 04-25-2013 13:25:29
Thanks!! I will check that out. Thanks again!!
