Anonymous-0
We have put new control lever in the pump and also have replaced the control spring and plunger in the top cover (celvis).
Also adjusted everything according to shop manual. When tested with plow using draft lever, the plow was not ploughing evenly. It sometimes lift by itself leaving land unploughed.
Any suggestion, what can be the problem. You expertise suggestion will be highly appreciated as it might save my hassle.
