Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 55 diesel starter parts wanted
fdt860
04-18-2013 19:16:22
On my 55 Diesel, I put brushes and brushes holder from a Delco Remy 37MT.
They need some adaptation. Basically, you need to made a new plate to hold the brush holder, or drill some others holes in the existing one to get all the brushes centered. On the autolite, the holes were the brush holder are riveted to the rear plate are not centered on the brush.
Those brushes are slightly shorter, but this doesn't matter. Then I have cut the hold brushes wires and connect them to the brush holders of the Delco.
Also, you will need to "worn" the new brushes a little bit because the rotor diameter is not the same.
massey 333
04-19-2013 06:46:26
 Re: 55 diesel starter parts wanted in reply to fdt860, 04-18-2013 19:16:22
Yes,I went to an extreme,because mine HAS to be able to start 24-365.We did a rebuild but it didn't look or act suitable for guaranteed starting in all weather temps.If it was something not being or not having to be started 100% time,then yes it can be done cheaper and maybe work fine.I just didn't want to(couldn't) take that chance,plus I can fix the Delco in hour or less.
