Massey 44 gear rarios,
Go to external_link, pick your tractor, then go to transmissions. You will find a maximum speed there, 5th is 1:1, should be able to do the math on the other gears.
See below ratios through the 44 drivetrain. These numbers are calculated from the number of teeth through the drivetrain. I wrote a whole book about this that has ratios for 100 other tractors too, plus a breakdown of all tooth counts inside. Take a look at the link below.
MH 44
(all numbers are crankshaft rotations per one revolution of the rear axle)
1st: 92.93
2nd: 61.62
3rd: 46.38
4th: 35.66
5th: 16.68
Best regards,
Zack Peterson
Author/Publisher: The Antique Tractor Pull Guide
www. antiquetractorpullguide .com
ATPG Gearing Book
