MF135 pop'n smoking
I have a diesel 135 that will start smoking and popping after running for about 20 minutes. Seems to be doing it when plowing and discing. Haven't notice the problem when using the sickle bar, Any guesses as to what is going on or about to go wrong?
Clyde
Have you changed fuel filters and cleaned the air filter recently? It sounds like it could be a fuel issue. You could try some diesel fuel conditioner/injector cleaner and see if it clears up. There may be something in the tank that is blocking fuel delivery too.
