Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: tie rod came loose
Tom from Buckeye Lake
04-11-2013 17:07:44
My 150 doesn't have grease fittings either on the outer tie-rod ends. You should have noticed steering play or slight wheel woble.
DavidP, South Wales
04-12-2013 12:36:46
 Re: tie rod came loose in reply to Tom from Buckeye Lake, 04-11-2013 17:07:44
I would agree with Tom. All ball joints give worning that they are well on the way to failing. This can be shimmying on the road or a delay in the wheels moving when you turn the steering. UK and most European tractors no longer have grease nipples fitted. It is possible to drill the sheet metal cap and fit a nipple in some. Most over here are a neat fit on the pin and have a retainer to hold the boot onto the body. Remove the retainer ring when new and pack as much grease as you can around the ball. Refit the boot. Excess will escape. The grease hopefully will work its way in. As far as the ball joint is concerned I would advise replacing it.....your life may depend on it.
DavidP, South Wales
