TractorLinks.com
Show Parts for Model:
Re: tie rod came loose
anteek
04-11-2013 13:04:25
That came loose because it wore out due to no grease. replace it and try greasing the tractor like the Lord intended. lack of lubrication has ruined many tractor.Buy a mule it will refuse to work when neglected.
ugabulldog
04-11-2013 13:41:16
 Re: tie rod came loose in reply to anteek, 04-11-2013 13:04:25
thanks, I think...... this one doesn't have a grease fitting on the bottom.
Tom from Buckeye Lake
04-11-2013 17:07:44
 Re: tie rod came loose in reply to ugabulldog, 04-11-2013 13:41:16
My 150 doesn't have grease fittings either on the outer tie-rod ends. You should have noticed steering play or slight wheel woble.
DavidP, South Wales
04-12-2013 12:36:46
 Re: tie rod came loose in reply to Tom from Buckeye Lake, 04-11-2013 17:07:44
Hi,
I would agree with Tom. All ball joints give worning that they are well on the way to failing. This can be shimmying on the road or a delay in the wheels moving when you turn the steering. UK and most European tractors no longer have grease nipples fitted. It is possible to drill the sheet metal cap and fit a nipple in some. Most over here are a neat fit on the pin and have a retainer to hold the boot onto the body. Remove the retainer ring when new and pack as much grease as you can around the ball. Refit the boot. Excess will escape. The grease hopefully will work its way in. As far as the ball joint is concerned I would advise replacing it.....your life may depend on it.
DavidP, South Wales
