TractorLinks.com
Show Parts for Model:
Re: Hand clutch on 55
fdt860
04-06-2013 08:46:36
I believe that you need to reinstall the shaft into the flywheel first.
That is not the usual method, but that will work.
The bearing at the end of the flywheel housing is not so tight on the shaft, so it is feasible.
I got a 55 Hand cluthc too, but I have to convert it to foot clutch because parts are impossible to find for the hand clutch version. So mine will be a hand and foot clutch, because I will just drill a hole in the foot pedal to allow using the hand lever.
Howard Larson
04-08-2013 20:56:54
 Re: Hand clutch on 55 in reply to fdt860, 04-06-2013 08:46:36
Thanks for the tip. Here is the other problem. How do you hold the springs down when you flip the that plate over onto the main assembly?? and getter all to work?? This all started because there was no cover over the timing hole and the mice packet it full off cherry bit and mouse crap. Thanks again
