Anonymous-0
Just picked up a 52 TO30. Been sitting for a long time. Got it up and running. Ran it for about 5 min at all rpm ranges. Had a bit of a tick to it so I adjusted the valves. The tick is gone now but one thing worries me. The valve cover and valve train area were dry. Put the gas tank back on and fired it up without the valve cover on. Maybe got one drop to come off the rocker shaft assembly in about a minute of running it. Am I getting worried over nothing? Anyone happen to run their engine without the valve cover on and see how much oil was suppose to be getti g up there? Also I pulled the plug out of the end of the rocker shaft assembly and ran it for a couple minutes and still not seeing any oil up there. Thanks in advance for any help with this.
