MF model identification and serial number
Roger in Iowa
May look at a MF that is in state of disassembly. Says tractor is size of 8N Ford. May be a model 35? Where is the serial number located and is there a model number anywhere as nothing on the hood?
Thx.
On the gas model the tractor serial nimber is attached to the lower left about right in front of your left knew when sitting on the tractor. The engine serial plate if it's a Continental is located on the left side engine block between the distributor and starter.
I have a 135UK and the serial number is on a tag on the dash to the right of the steering wheel below the throttle lever.I believe it's only located there on UK models.
