TractorLinks.com
Show Parts for Model:
Re: MF 65 Noises
Eric in IL
04-01-2013 16:44:37
How is your clutch functioning ?
It is a two-stage clutch, does the p.t.o. stop spinning when the pedal is fully depressed ? If yes, at that time there is nothing turning/moving in the transmission area except the clutch itself.
So could the clutch itself be the source of the knocking ? If it occurs at mid to high r.p.m.'s, maybe it is a broken clutch facing that is forced outward thus hitting the transmission case when subjected to the higher revs.
There is an inspection cover under the clutch if you chose to have a look see.
Traktor
04-02-2013 07:03:58
 Re: MF 65 Noises in reply to Eric in IL, 04-01-2013 16:44:37
Eric,
The PTO stops when the clutch is fully depressed. It is certainly possible that there is something wrong with the clutch since you tell me that nothing in the transmission is turning when the clutch pedal is fully depressed.
I am going to re-fill the transmission and really pay attention to the effect of the clutch on the noise. Thanks very much for the reply!
Eric - I am in NW Illinois near Moline. Where in Illinois do you live?
Eric in IL
04-02-2013 08:28:47
 Re: MF 65 Noises in reply to Traktor, 04-02-2013 07:03:58
I live near Litchfield.
I have given more thought to my first post. Since your clutch is functioning properly, the knock would not be coming from a loose friction pad because that noise would stop when the clutch is disengaged.
But since other components of the clutch would still be spinning, your noise could still be clutch related.
