Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: MF 304 workbull instant reverse leak / pump?
Phil Tibbetts
03-28-2013 17:57:49
I don't know for sure where your leak is coming from, but a couple years ago I had my 205 with the instant reverse split and while it was apart I replaced the seal in the front of the instant reverse case. That could be the source of your leak. Does the oil level go down? If you remove the cover under the bell housing you should be able to find out where the oil is coming from.
03-28-2013 18:54:16
 Re: MF 304 workbull instant reverse leak / pump? in reply to Phil Tibbetts, 03-28-2013 17:57:49
That's the seal I think is gone, the book seems to indicate that usually the seal goes due to the bearing in the pump being damaged. I just want to have my bases covered before I split it. I also can't really remove the cover from the bell housing as it is the cross brace for the front end loader. Thanks, Sam
