I acquired a MF 165 non running diesel for the loader to put on my original MF 165. I had it going for about 10 minutes before a rod bolt blew through the side of the block. So now I am focused on stripping off good parts to put on my tractor. The "parts" tractor has rear hydraulics which I would like to put on my tractor. It is plumbed into the PTO cover. So here are my questions:
1-will my tractor have the pump needed to run the rear hydraulics?
2-if the answer is maybe/maybe not, how do I tell?
3-since the parts tractor has new tires that are loaded and have wheel weights, could I split the tractor at the back of the gearbox and swap it onto my good tractor?
Thanks for any and all responses.
Doug
Doug
