massey ferguson 65 decathe proper l locations
jedagi
I"m ready to put my decals on. Im not sure of Some of the decals proper location. The starting instructions decal, the never ride on fender etc decal, the only pull from draw bar or lift arm decal. And does the clean oil bath breather daily decal go on the oil cup.
Any help will be appreciated.
It depends if its the dieselmatic or not Im pretty sure your the guy i posted on when you were shopping for decals. If thats the case the starting instructions go to the left of the key switcth. The aircleaner was about eyelevel above the sheet metal that holds the hood panels together. Thats where my original one was when I sanded it. The no riders one I put on the left fender. The pull from drawbar one I put on the right fender. Im not sure on these last two as mine had none of these two on it when I sanded it. I hope this helps Id put up pictures if I knew how. Mine came out looking pretty neat. I took it out and moved wagons with it Friday its good to have it out of the shop after a long winter of breathing dust and huffing paint.
Yes, mine is a high crop diesel native. I've seen the pull from draw bar decal placed left of the pto shaft/top link arm on the rear end housing. I see a decal in many pictures. Its on the right side of the lower dash panel. I guessed it to be starting instructions.
Thanks
Keep them coming.
