Massey 44 Front Wheel Seals
Scott(IN)
I need to replace the front wheel seals on a Massey 44 diesel. These are the rims that have the heavy cast center. The part # is 21334A which is not available. Wonder what other people have done. Guy at farm store crossed this number to another number, but that seal is not right. Can't believe I am the only one with this problem.
On my 44 and 44 special I took the seal to my local bearing shop and matched it up.The ones I used ended up being regular oil lip seals.I installed them into the hub then cut a felt spacer out of a old felt boot liner.I put the felt between the seal and the dust cover and installed the hub.I have the seal numbers some where in my books.I will find them and post it on the site for you.If you have the big cast hubs you must be working on a 44-special.
