Identifying a Ferguson
Don Rudolph
A friend has asked me to help him identify the model and find a replacement manifold for his Ferguson. There is no serial tag. It has individual brake pedals that come forward from the back axle, one on each side of the tranny housing,if that helps any. Is there a 20 or 30 model? And can you get new manifolds for them? Thanks! Don
Could be a to 20 or 30. If it has a hole in the inst console it is a 30 otherwise a 20. You can get new reproduction manifolds but I have found them to be of poor quality. I have on original for sale on eBay needs a stud repaired but have priced it accordingly. 802-782-2409
Most of the TO 20's I have seen just have a footpeg and the TO 30 usually have a running board. You should be able to get some numbers off of the engine. By the way, David at Vermontventuresllc is a good, fair guy to deal with if he happens to have what you need.
Tequila,
Thanks for the good review. I am quite sure the to20 and to30 manifolds exchange. The one I have needs one of the stud holes drilled out and a bolt would need to be used instead of a stud. 50.00 plus shipping.
