| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: MF-165 teardown status
[Return to Forum]
| Author |
[Modern View]
| jwillett2009
03-09-2013 05:22:57
142.167.183.40
Hi gentlemen,
I've got a little update on my tractor issues that some of you had been helping me with.
My MF-165 was not starting after an overheating incident. Suspecting broken rings or damaged pistons, and following the advice I was receiving here, I decided to take the cylinder head off and have a look. Well, I learned quite a bit.
Fuel injector 1 was dry and was full of a hard dry shiny carbon.... almost certainly cylinder 1 was not firing.
Fuel injectors 2 through 4 were heavily scaled and looked almost like they were dipped in mud.
The head gasket was broken between cylinders 1 and 2 and again between 3 and 4.
The fact that it run as long as it did is amazing.
The top of the cylinders have a lot of "pitting" but doesn't look too bad. I can read the stamped numbers on each of them and read the "front" labels through the pitting so its not deep. There is no evidence of major damage to the pistons like melting. There is some light wear in at the top of where the upper ring would stroke. Haven't determined if it will require new liners yet.
I have decided to try to completely rebuild this tractor. Even though I've probably found the major issues, I am going to complete the teardown. I experienced quite a bit of leaking oil prior to these issues so I want to get to the oil seal on the crank and replace the o-ring ect.
The manual talks about the motor as if it was sitting on a table somewhere. I called it an early night last night prior to removing the oil pan in the interest of safety. I wanted to make sure that I had a sound plan for supporting the tractors front axle (and rear end) once the pan is removed. I believe this is all the structure for the tractor.... right??? I want to remove the pistons to examine them and also to have a good look at the rings and cylinders.
What's the best way to do this from an "amateur" point of view (in terms of garage). I am working in a garage on a concrete floor but not set up for an heavy hoisting. I don't have any special jacks or cranes. I have a small sawmill so I have lots of dunnage to crib with.
Hopefully, we can keep this thread active and document this rebuild.
Jamie |
| Vtparts
03-09-2013 07:12:56
198.228.200.26
Re: MF-165 teardown status in reply to jwillett2009, 03-09-2013 05:22:57
| I have just parted a 165 should you need parts 802--------- |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
