Show Parts for Model:
Re: 165 hydraulics question(s)
Stick welding
03-05-2013 22:05:06
The draft control isn't used to control the height of the 3 pt. Draft control is only used with ground engaging implements. Without seeing your set up, I'd guess you have 2 levers on the trans. cover. Only one is plumbed because the other one(usually the inside one) is internally plumbed to operate the 3 pt. from the side 3pt. controls. You pull it back and the side controls should work the 3 pt. You can't use the aux. at the same time and that lever must remain in neutral. When using the aux. hyd's., the 3 pt. lever has to be in neutral and the side controls all the way up. Draft control all the way up and position all the way up, then pushed over past the normal stop and pulled up even further into constant pumping position. The outside lever on the trans. cover would be used to operate the aux. hyds' or pulled back to supply oil to the seperate loader valve. If you could post some pictures of what you have would help.
MT in PA
03-06-2013 06:40:02
 Re: 165 hydraulics question(s) in reply to Stick welding, 03-05-2013 22:05:06
Stick welding
You have the configuration correct.
After the adjustment this is the way that it is working though. To clarity. The Position Level is acting as a high position stop and the Draft Level is acting as if geared to the arms. If the position lever is in full up and I move the draft from mid-point to up, the arms follow the draft lever. To make them go down I have to move the lever forward (dumping the pressure I assume). Constant pumping does not seem to change anything. That does not seem correct to me either but this is my first tractor so I donít know anything for sure.
In as far as the valves, when I received the tractor last spring there was no reaction from Draft or Position control. The only way to operate the arms was with the valve. Holding the valve back until the arms were in the desired position, moving back to the center when they were where I wanted them. I would disconnect the loader hoses before doing this. The loader is a QD type and the plumbing from the valve runs to the QD lines. When I wanted to use the loader Iíd connect the hoses and move the lever to forward. When I would operate the loader valves the arms would move to the full up position before the loader (bucket or arms) would mover. In an attempt to fix this issue I moved the hoses from the outside valve to the inside valve. That allowed the loader to work without the arms moving, so I left the plumbing that way.
Now after making the sync. Adjustment I am back to the same condition but now I have some reaction out of Draft and Position control (although it may not be acting correctly)
You are saying that the inside valve is internally plumbed. Is the inside valve supposed to be isolated from the outside valve? I get the feeling that there is some kind of port or leak connecting both valves. When I have the lever in the loader position and arrive at the max position on any hydraulic tool the valve pops back to the center as if something is back feeding the valveÖ.In some way the 3pt and the remote loader are hydraulically connected at the same time no matter the valve position. That is why I think maybe the valves need to be re sealed?
Thanks for all the help. I really do appreciate the advice. Iím usually pretty good with this kind of thing but this one has me stumped. Too many variables..
Iíll try and load pics tonight if you think it will help.
Maybe video over the weekend if no one has a solution before then.
Thanks again, MikeÖ
Stick welding
03-06-2013 18:37:02
 Re: 165 hydraulics question(s) in reply to MT in PA, 03-06-2013 06:40:02
I'm not a real expert on these but there has to be some internal plumbing for the inside valve to control flow to the side 3 pt. controls. There could be something messed up with the linkage for the side controls. There's some MF experts on here that could help you a lot more than I could.
