Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 165 hydraulics question(s)
Stick welding
03-05-2013 22:01:29
The draft control isn't used to control the height of the 3 pt. Draft control is only used with ground engaging implements. Without seeing your set up, I'd guess you have 2 levers on the trans. cover. Only one is plumbed because the other one(usually the inside one) is internally plumbed to operate the 3 pt. from the side 3pt. controls. You pull it back and the side controls should work the 3 pt. You can't use the aux. at the same time and that lever must remain in neutral. When using the aux. hyd's., the 3 pt. lever has to be in neutral and the side controls all the way up. Draft control all the way up and position all the way up, then pushed over past the normal stop and pulled up even further into constant pumping position. If you could post some pictures of what you have would help.
Stick welding
03-05-2013 22:06:13
 Re: 165 hydraulics question(s) in reply to Stick welding, 03-05-2013 22:01:29
Sorry for the double post. I added a sentence.
