MF 85 does it have a transmission cooler?
My 85 that was changed to a perkins a4.300 engine doesn"t have a cooler up by radiator and I don"t know if is suppose to have one or not. It doesn"t look like any place to attach one or that the lines have been altered. I have a neighbor with one that is gas and it has a cooler up front.......
if it is suppose to have one what lines go into it>? and where do that go to?
if not........I am good. I hope
Also on the brake pedal side toward the back of the foot rest I am suppose to have a long spring that goes down vertical from kinda under the seat on the brake side........I don"t have the spring and don"t know what it would be for.
here it is in the shop in streaming video
They originally had a cooler right against the front of the radiator. The super 90 moved it forward and to the left. It connected in the return line from the power steering.
I wonder what the pressure is coming out of power steering pump. I don't have multi-power and wonder if they came out without a cooler if no multipower. The IT manual doesn't mention a cooler on the disel engine models in removing the radiator and it does on the gas models.........
I have a good cooler off of a ford pickup I could splice in if the pressure is not too high since it has hose instead of steel fittings?
I am also wondering about adding a spin on hydraulic oil filter to this thing somewhere too
Oil cooler is on the return side of power steering valve, and is supply line to input shafts retainer in trans front. Pressure is 150-200 at PTO control valve, is regulated by a valve built into retainer cover. That is the pressure the cooler has do deal with. If tractor is used hard in hot weather cooler is a good idea. If not, it would not be needed. I had an 85 gas that cooler was removed from, no trouble as it never ran more than 2 hours each time it was used. Super 90 had a cooler too, but was designed much different than 85 was.
So, sounds like if I want to brush hog with it in the summer, I had better come up with a cooler? The lines don't look like they have been changed or altered. I wonder if a transmission cooler off of a Ford pickup with the rubber hoses could handle the pressure? Or should I flare the ends on the cooler and make up some short hydraulic hoses?
THANKS
here it is in the shop streaming video
We just finished parting out a Massey 85 that had multi power. The pump has been sold. Lots of 85 parts in stock.
802-782-2409
The serial tag states MF85 RGM 801343 this tractor had a multi power pump in the transmission just below the lower right step.
