TractorLinks.com
Show Parts for Model:
Re: MF 85 does it have a transmission cooler?
Alec
03-02-2013 20:05:06
They originally had a cooler right against the front of the radiator. The super 90 moved it forward and to the left. It connected in the return line from the power steering.
farmerscotty
03-02-2013 20:17:58
 Re: MF 85 does it have a transmission cooler? in reply to Alec, 03-02-2013 20:05:06
I wonder what the pressure is coming out of power steering pump. I don't have multi-power and wonder if they came out without a cooler if no multipower. The IT manual doesn't mention a cooler on the disel engine models in removing the radiator and it does on the gas models.........
I have a good cooler off of a ford pickup I could splice in if the pressure is not too high since it has hose instead of steel fittings?
I am also wondering about adding a spin on hydraulic oil filter to this thing somewhere too
Bob N.Y.
03-03-2013 05:09:04
 Re: MF 85 does it have a transmission cooler? in reply to farmerscotty, 03-02-2013 20:17:58
Multi-Power wasn't available yet when the 85 was being built.
VTParts
03-03-2013 10:29:54
 Re: MF 85 does it have a transmission cooler? in reply to Bob N.Y., 03-03-2013 05:09:04
We just finished parting out a Massey 85 that had multi power. The pump has been sold. Lots of 85 parts in stock.
802---------
Dieselmatic
03-03-2013 18:41:44
 Re: MF 85 does it have a transmission cooler? in reply to VTParts, 03-03-2013 10:29:54
You parted something out, but it wasn't an 85. What was the ser no?
VTParts
03-03-2013 18:53:50
 Re: MF 85 does it have a transmission cooler? in reply to Dieselmatic, 03-03-2013 18:41:44
The serial tag states MF85 RGM 801343 this tractor had a multi power pump in the transmission just below the lower right step.
Dieseltech
03-02-2013 21:42:56
Oil cooler is on the return side of power steering valve, and is supply line to input shafts retainer in trans front. Pressure is 150-200 at PTO control valve, is regulated by a valve built into retainer cover. That is the pressure the cooler has do deal with. If tractor is used hard in hot weather cooler is a good idea. If not, it would not be needed. I had an 85 gas that cooler was removed from, no trouble as it never ran more than 2 hours each time it was used. Super 90 had a cooler too, but was designed much different than 85 was.
farmerscotty
03-03-2013 06:04:35
 Re: MF 85 does it have a transmission cooler? in reply to Dieseltech, 03-02-2013 21:42:56
so is the 150-200 psi what is at the power steering low pressure side?
Dieseltech
03-03-2013 11:14:26
 Re: MF 85 does it have a transmission cooler? in reply to farmerscotty, 03-03-2013 06:04:35
Yes, this is return oil to PTO closed center shift valve. Pressure is regulated by a valve in transmission front plate.
farmerscotty
03-03-2013 05:58:19
So, sounds like if I want to brush hog with it in the summer, I had better come up with a cooler? The lines don't look like they have been changed or altered. I wonder if a transmission cooler off of a Ford pickup with the rubber hoses could handle the pressure? Or should I flare the ends on the cooler and make up some short hydraulic hoses?
THANKS
Dieseltech
03-02-2013 21:58:27
Spring you have missing is for draft control follow up linkage, senses draft control frame movement.
