MF 85 power steering filter.....what is it?
I have a 85 I am cleaning up and going thru. It doesn"t have a filter in the power steering cartridge up by the battery box. Is it the same as the transmission filter?
I cannot find a number for it or anything wanted to order one online today and get it on its way.
I have drained the transmission all three drain plugs and am going to run some diesel thru it.and then clean the transmission screen. Do I take the power steering pump off the side to clean a filter on it?
THANKS ALL
live webcam of tractor in the shop
just finished going thru mine,picked it up in the fall. part # for upper p.s.filter is 185541m1
it is a cork or hard material style. it is NOT same as trani filter. definitely pull off lower ps pump on right side of tractor and clean intake screen. there is an o-ring in upper corner(inside)on housing plate so make sure it doesnt get munged up. not sure where i got filter,either local dealer found or i did parts search on external_link. good luck scott
I have removed the power steering pump and removed the strainer tube attached to the pump.
Is the screen part of the tube suppose to have a "hole about the size of a pencil in the end of the screened tube? It has a magnet inside the screen part and up the tube part where it attaches to the pump. But, I don't know if it is suppose to have the "hole" in the end cap of the screened in tube.
Hope that makes sense.
me working on the mf 85 in real time
mine didnt have a hole or magnet in the bottom,there was a small plug or cap in the end. im assuming maybe they removed it and put in the magnet seems like a good idea. fyi, gasket for that ps pump is obsolete,iused gasket maker.
