Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Perkins 354 turbo smoking
Dieseltech
02-28-2013 15:53:49
Unless you are trying to greatly increase power larger hole tips or more holes are not needed. For example, my S90 puller still has 4 hole tips with holes only one size larger than stock. Pump has been modified to deliver over 250 CC per thousand strokes, stock is 68. PTO hp, short time only will hit over 200 with 35 pounds boost pressure with very little smoke under boost. Smokes like crazy with no boost. Stock engines with larger tips when not needed will actually smoke more as fuel can't mix with air charge as it should. Newer engines that use more holes have smaller, not larger hole sizes to help with mixing in piston bowl.
