Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: massey ferguson brakes
[Return to Forum]
patrick b
02-28-2013 06:55:12
74.127.69.164
I am helping a few neighbors who just started working on a mf 165.The tractor sat in a field for 10 years.The rear left side brake is seized.All attempts to break it loose have failed,including dragging the machine for quite a long distance.When the tractor is jacked up on that side,there is just a small ammount of play in the wheel,about a half inch bach and forth.Is there a trick that will unseize this brake?Or does it have to come apart?
[Reply]   [No Email]
patrick b
02-28-2013 17:40:51
74.127.69.164
 Re: massey ferguson brakes in reply to patrick b, 02-28-2013 06:55:12
Thanks all,I will take these tips to the guys this weekend and see where we end up.We really do not want to take this apart.
[Reply]  [No Email]
Gearhead210
02-28-2013 09:26:39
72.241.59.210
Sounds like the brakes- if it was the transmission it would be both wheels. The brake expander plates are known for sticking on, or it could be that the brake linings are rusted to the expander plates or the axle housing. I would loosen the adjuster bolt on the axle housing (faces forward towards running board) and try "rocking" the tractor forward and backwards. If that won't work then the axle housing needs to come off- that could be a pain if the brake linings are rusted to the pressure plates. Maybe trying to pull the rubber boot off the brake adjuster rod, and spraying some penetrating oil in there would loosen stuff up- but it would ruin the brake discs. Sounds like they need to be replaced anyways though.
Good Luck,
Richard
[Reply]  [No Email]
Chip812
02-28-2013 08:17:44
216.226.180.3
Why are you sure it's the brake and not the transmission? How are the rubber boots around the shifters? If cracked (or missing), then lots of water in the transmission. Especially after 10 years.
[Reply]  [No Email]
DavidP, South Wales
02-28-2013 14:21:46
2.101.120.119
 Re: massey ferguson brakes in reply to Chip812, 02-28-2013 08:17:44
Hi all,
Gearhead is almost certainly correct in his posting that it is the brakes that are seized. Besides being the only thing that will potentially rust without immersion in water, they can seize on in a short time. The very limited wheel movement is due to the take-up in the epicyclic reduction unit just inside the hub.
Have you checked that the operating arm/s are free? The adjuster pivot bush in the centre of these arms can seize as well. Remove the adjuster nut/s and remove the arm pivot housing.
If the actuator is seized in the 'on' position you might just be able to get a pry bar onto the metal discs to break the rust.
DavidP, south Wales
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
