Loader 202 Workbull?
BobHnwOh
Have a 202 Massey Workbull,want to sell front loader,or whole tractor,any ideas what I could get for it,loader is good condition,rest of tractor real rough,TIA.
I bought a 202 (not work bull) in December with 200 loader on it, also has 3 point hitch but the engine is stuck for $600 near Parkersburg, West Virginia. Tires are good and sheet metal is good. Don't know if this helps or not. Keith
Pics.
The value is going to depend on a lot of things. Does it run? How rough is rough? Things like your location, and the market are going to have a large bearing on what you're going to get.
I think I paid too much but I bought a running 202 with 102 loader and 220 backhoe a few years ago for $5000. It ran and everything operated but it has needed a lot of things since I got it.
Too bad you're not close to where I am, I'd make an offer just for parts.
If the internals are as old and worn out as the externals appear to be, $500-$1000 non-running, $1000-1500 running. If the internals are amazing, IE: this is some kind of "sleeper" tractor with documented low-hour rebuild or replacement engine, running gear, wheel bearing/seals/brakes/PTO, etc. all gone through, then $1500 up to $3500
(quoted from post at 13:55:53 02/28/13) If the internals are as old and worn out as the externals appear to be, $500-$1000 non-running, $1000-1500 running. If the internals are amazing, IE: this is some kind of "sleeper" tractor with documented low-hour rebuild or replacement engine, running gear, wheel bearing/seals/brakes/PTO, etc. all gone through, then $1500 up to $3500
That loader looks like it's been busted up an patched as well so keep that in mind as you try to sell it.
