| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: Re: Perkins 354 turbo smoking
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| V8 farmer
02-27-2013 01:24:55
94.22.43.6
Thanks for the info Dieseltech. My tractor is 1985 MF 3525, do you know the plunger size of this pump? It also runs a little rough at high rpms (when it smokes), could it be that the speed advance is not working properly? |
[Reply] [No Email] | |
| Dieseltech
02-27-2013 05:12:12
98.206.80.148
Re: Perkins 354 turbo smoking in reply to V8 farmer, 02-27-2013 01:24:55
| Post the despatch # of the injection pump, then I can look at the test plan to find plunger size and advance spec if fitted. Not sure what pump # is on a 3525. Brother had one, but traded it so I can't look at his. |
| V8 farmer
02-27-2013 06:10:03
94.22.43.6
Re: Perkins 354 turbo smoking in reply to Dieseltech, 02-27-2013 05:12:12
| Heres the numbers DPA 3269F911 DSA 451 Ser 01185 JCG 37744LX/4 2630 |
| Dieseltech
02-27-2013 21:22:58
199.16.223.2
Re: Perkins 354 turbo smoking in reply to V8 farmer, 02-27-2013 06:10:03
| Pump hydraulic head is 4, 7.0 mm plunger size, about the same rate as 2 10 mm. Advance is 4 degrees pump, 8 degrees engine. If advance is coming in too late, it will smoke more. Try this, there are 2 springs under the 15/16 cap that has a 5/16 screw in it on the advance block, remove the inside spring and replace cap. Work tractor to see if that helps smoke level any. If not, I would remove all injectors and popcheck to see if all holes are open. Most Perkins injectors have 4 hole tips, if 1 hole is plugged on 1 or more injector power will go down and smoke will go up as incomplete combustion will occur since too much fuel through 3 holes will not have enough air to burn correctly. Have seen this on MF 1150 that was smoking too much and had lost power. |
| V8 farmer
02-28-2013 11:09:05
94.22.43.6
Re: Perkins 354 turbo smoking in reply to Dieseltech, 02-27-2013 21:22:58
| Thanks again, great info indeed. I havent checked the injectors yet because previous owner told he changed them recently (few hundred hours ago). But I'll check them again and see if its possible to get bigger/5-hole injectors for it, I suppose that would help too? At least thats what they are doing for NH 7.5 litre engines around here, heard that they get few extra hp just by swapping the nozzles to 5-hole. |
| Dieseltech
02-28-2013 15:53:49
199.16.223.2
Re: Perkins 354 turbo smoking in reply to V8 farmer, 02-28-2013 11:09:05
| Unless you are trying to greatly increase power larger hole tips or more holes are not needed. For example, my S90 puller still has 4 hole tips with holes only one size larger than stock. Pump has been modified to deliver over 250 CC per thousand strokes, stock is 68. PTO hp, short time only will hit over 200 with 35 pounds boost pressure with very little smoke under boost. Smokes like crazy with no boost. Stock engines with larger tips when not needed will actually smoke more as fuel can't mix with air charge as it should. Newer engines that use more holes have smaller, not larger hole sizes to help with mixing in piston bowl. |
| Masseynut(Australia)
02-27-2013 03:02:50
60.231.51.218
| I'd also take a look at the auxillary drive shaft and worm gear, especially if the engine has bulk hours on it. When these show signs of wear, pump timing can be compromised, causing rough running and excess smoke issues. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
