Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: MF35 Petrol Vanguard valve clearances clarification
[Return to Forum]
trains
02-26-2013 20:34:55
118.210.33.236
Hi all.
Just after some clarification.
Most online searches bring up 0.013 thou hot for inlet and exhaust.
Which I set them to this morning.
Most I thought were tight at 7-8 thou.
Engine was nice and quiet beforehand, now you can hear a distinct valve train tappet noise.
Then it started raining, so put cover on and went inside and looked at the workshop manual over a coffee and came across
Inlet 12' cold
Exhaust 8' cold
I used to be a mechanic, and have set up many solid valve lifter motors before, some race engines etc, so I have a reasonable feel for correctly adjusting these things.
trying to sort out what clearances these should really be set to.
Thanks again.
Trains
"Save the Whales..............Collect the Whole Set"
[Reply]   [No Email]
Tony in Mass.
02-27-2013 16:08:55
76.127.225.182
 Re: MF35 Petrol Vanguard valve clearances clarification in reply to trains, 02-26-2013 20:34:55
A 'Vanguard' engine???? One of those pommie-mobiles so ugly they're cute??? So that would be a ... 'Standard Motor Company' engine???? Do you here the thumping in the distance? The sound of my feet running away...
I just did the valves -cold- on my Continental Z134 being rebuilt, book says '.015" cold'... and believe me it's cold.... yeah, I'd rather have them a bit loose and noisy than too tight and burned up. Now if we were working on Empire classics, like my kiwi made 1963 Vauxhall Victor Velox, we would strive for Swiss watch precision... but for st... engines like yours...
Your stems have rotors on some, not the others too eh? I guess it's a new industry standard... ohhh... I said it again....
[Reply]  [No Email]
richardinnz
03-02-2013 02:04:32
125.239.163.254
 Re: MF35 Petrol Vanguard valve clearances clarification in reply to Tony in Mass., 02-27-2013 16:08:55
Actually that is a kiwi ASSEMBLED Vauxhall, We havn't had Vauxhalls here for years, Holden now, even the Vauxhalls are badged as Holden! I don't think there is any car assembly here now, I have a kiwi assembled Misubitsi,a Landrover, and an International ACCO truck, all from the 1980s and I think they would have been about the last Kiwi assembly jobs.
[Reply]  [No Email]
Tony in Mass.
03-02-2013 06:34:13
76.127.225.182
 Re: MF35 Petrol Vanguard valve clearances clarification in reply to richardinnz, 03-02-2013 02:04:32
Cripes. Just thought of it after I clicked 'submit' below... didn't Standard make engines for Farmall and Allis Chalmers- and Fordson?
Anyway Richard, I was living on the long black cloud in the early 80's? 83-84? And my Victor was the only car I could afford that didn't look like a foreign object from outer space.... Zephers and Scoda for instance??... mine had '3 on the tree', UK mades apparently were all floor shift and nicer interiors. I was in Tauranga- where are you?
[Reply]  [No Email]
Fergie Bach
02-28-2013 06:20:29
92.26.182.241
The standard engine as fitted to the "Vanguard" and also in lower compression version to all those super reliable TE20 Ferguson tractors is/was a lovely engine. Just needed a bit of servicing.
IMHO much better made than early Vauxhall stuff. In fact precision is not a word that come to mind for those. Horrible tappet arrangments often.
Stick with your Vanguard engine. It will still be going after all the old Vauxhall engines are Toyotas.
[Reply]  [No Email]
trains
02-27-2013 14:30:11
118.210.0.236
Thanks MasseyNut and Phil Tibbets,
Yep MasseyNut, they have the rotating tips on the Exh valves.
Will reset them this morning as its nice and cold here now.
Will keep an eye on them over the next year to see how much they settle in after this adjustment, it all looks to be in pretty good condition with good oiling of the rocker arms etc.
Valve noise is not like a noisy stuck hydraulic lifter, but the gentle tappet noise you hear, distinct but not obtrusive I should have mentioned.
Will post up again what difference it makes when its done.
thanks again chaps, much appreciated, hope that others find this helpful when there about to do their valve clearances on their mf35 petrol.
Trains
[Reply]  [No Email]
trains
02-27-2013 18:42:59
118.210.99.241
 Re: MF35 Petrol Vanguard valve clearances clarification in reply to trains, 02-27-2013 14:30:11
Ok, readjusted to 8 thou exhaust and 12 thou inlet, with very light drag on the feeler gauges, and its quieter, but you still get the nice valve train noise, better than no noise as before, and them being too tight and suffering burnt valve issues as others have mentioned before.
Hi Tony in Mass,
Not entirely sure what your post was about, have I incorrectly described the fergy standard motor by naming it a vanguard motor ?
Only using it for clarification as others had used it when I was searching for parts.
Trains
[Reply]  [No Email]
Tony in Mass.
03-02-2013 06:18:30
76.127.225.182
 Re: MF35 Petrol Vanguard valve clearances clarification in reply to trains, 02-27-2013 18:42:59
Well, I am certainly not the authority on these things, but I suppose the family tree would be 'Standard Motor Company LTD, makers of Vanguard automobiles AND diesel AND petrol engines- installed in Harry Ferguson tractors'. Now Richard, Evan and fergiebach would know much more than I- btw, where are you??
[Reply]  [No Email]
Phil Tibbetts
02-27-2013 06:15:11
208.93.14.38
I would rather see them a little loose than tight. You won't burn a valve if they are loose. IMO
[Reply]  [No Email]
Masseynut(Australia)
02-27-2013 02:34:26
60.231.51.218
Inlet .012" and exhaust .008" is correct provided the exhaust valves have the rotator caps fitted.
If they have been lost, go for .012" on both.
You may get tappet noise because the rocker tips have a worn indentation of the valve stem on the underside. This will of course, give you a larger gap.
Just a thought,
Evan.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
