TractorLinks.com
Show Parts for Model:
Re: MF165 Brakes
DavidP, South Wales
02-26-2013 12:06:51
Hi,
Yes, there is a seal on each side of the brake compartment and its essential that both are replaced when servicing the dry brake system.
Yes, you do have to drain the oil.
The diff-lock cam has a spring to release it. You will need to remove the roll pin and can before you can remove the inner plate. You may need a clamp to compress the spring to fit the roll pin on reassembly.
Presumably you won't have far to travel to collect parts from A******e if I'm thinking correctly!!!!!
DavidP
