TractorLinks.com
Show Parts for Model:
Re: mf 35 3 point pin extraction
Masseynut(Australia)
02-26-2013 02:31:45
You will need to remove the appropriate trumpet (axle) housing. The pin has a retaining nut located internally. The pin is tapered and locates in a tapered bore in the axle housing. Drain off the rear end oil, remove the rear wheel and using lifting equipment, unbolt and lift the axle housing from the centre housing.
Check the condition of the housing before fitting a new pin. If the existing pin has been loose, causing the pin to snap, you may need to use a retaining compound (loctite, araldite, etc) to carry out a successful repair. If the loose pin has badly flogged out the seat, a replacement housing may be the go. Also not a bad option to replace both when one side breaks. This can be done by removing the L.H.S. axle housing which then gives you access to the R.H.S. pin retaining nut, once the diff centre has been lifted out. Just a thought, Evan
