Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: massey harris 44
english
02-21-2013 16:38:44
My goodness,the stupid replies show these are not Massey people replying.Dick H has the correct answer.Forget all the engine and rearend numbers.Check the trans cover.
BIG RUH
02-24-2013 11:57:10
 Re: massey harris 44 in reply to english, 02-21-2013 16:38:44
There was a resent auction that had a Massey Harris.Serial # and # on transmission read 44GR. Engine was a 382, Hood & grill were from a 555 and the wheels were from a 44 special. just curious what model was this?
missouri massey man
02-24-2013 12:28:46
 Re: massey harris 44 in reply to BIG RUH, 02-24-2013 11:57:10
I'm thinking I was at that same auction. The name of the small town in Illinois is now escaping me, but if the MH Hybrid you are describing isn't the same one, it has to be close to it....what WAS the name of that town ??? Lots of tractors in pretty rough condition as well as the sheds, barns and all.
BIG RUH
02-24-2013 14:21:15
 Re: massey harris 44 in reply to missouri massey man, 02-24-2013 12:28:46
Hecker
missouri massey man
02-24-2013 16:51:41
 Re: massey harris 44 in reply to BIG RUH, 02-24-2013 14:21:15
That's right !!!! Left on 156 then north a few miles. Did anything go home with you that day?? I got some six dollar chain hoists, then had to carry them a half mile to the truck...
You from Missouri too??
BIG RUH
02-24-2013 19:23:40
 Re: massey harris 44 in reply to missouri massey man, 02-24-2013 16:51:41
Check your PM's on ATF and you'll be enlightened
missouri massey man
02-22-2013 05:36:03
You can go by the recommendation by DickH only if you can be guaranteed it is a totally uncompromised unit with nothing having been changed from the factory from date of manufacture. However,Mark49 is absolutely correct about so many mix/matched engines to rear ends all with subtle differences of which he points to several very well.
It may take just a little more time and experience with the old Masseys before you can absorb enough with a quick look to tell on your own. Hang in there and be patient, the knowledge will come very easy.
mark49
02-21-2013 17:31:34
Mr. English, I highly doubt that you have as much time working on the larger Masseys as I do. Working in a field may be another matter. The numbers stamped into the transmission CASTING only tell you the what the transmission originally belonged to. If you have not seen a 44 with a 277 or a 30 with a 260, I would suggest it is you who is not a Massey person. The 49 in my sig refers to my 44GR, serial no. 7958, frame cast on 4/19/49.
english
02-22-2013 16:56:57
 Re: massey harris 44 in reply to mark49, 02-21-2013 17:31:34
I would suggest I probably have twice as many Masseys as you have and have been around,on and used them for nearly 70 yrs.Serial numbers are always stamped on the top of the transmission cover!!!
missouri massey man
02-23-2013 03:56:25
 Re: massey harris 44 in reply to english, 02-22-2013 16:56:57
....but how revelant would that number that is stamped on the top of the case be if that housing had been swapped out with a donor tractor? Are we saying here that the serial number of the tractor goes with the rear end and not the engine and front half of the frame even though a regular 44 rear end could have been installed on a 44 Special front half?? I am now totally confused and need enlightenment. Do not read anything into this other than a simple request for input.
rustred
02-22-2013 06:19:15
2nd that, i have been around the 44 and specials since 5yrs. old and sure can tell the diff. at a distance without looking at the tag! also he was saying he cant find the tag!
Copyright © 1997-2015 Yesterday's Tractor Co.
