Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Thermostat removal, MF165
02-20-2013 21:16:37
White smoke at exhaust means engine is getting fuel but not high enough compression heat to burn properly, due to low compression and/or low cranking speed. 203 is a good starting engine IF compression is in good condition. If you have excessive blowby from vent tube I suspect piston/rings/sleeve damage. Had a 354T recently, too much either had broken all ring lands and rings. It would barely start, but when hydraulic pump kicked in it would die. Blowby fumes looked like it could have been the exhaust pipe, so much air was coming out.
