Anonymous-0
While my 230 is down to replace the water pump,fan & radiator I thought I'd split it again to look at the clutch adjustment. I put a new 2 stage clutch assembly in when I got the tractor. It came from a Massey dealer and they said it come already adjusted just slap it in. NOT! The pto will not engauge with the motor running. I adjusted the 3 bolts you can get to through the inspection plate but it still won't work. What should the measurements be set at for it to work correctly? Also I read somewhere the pto had three positions one forward neutral and one backwards. One for ground speed and one for engine speed is this true? Thanks.
