Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 44 partial lock up with head pulled off
[Show Entire Topic]  [Return to Forum]
marloweg
02-17-2013 19:34:57
207.118.179.152
think you started on the wrong end of the engine. did the engine knock at all? could be a rod bolt came loses or a bolt out of the pressure plate,i see it has a hyd pump on it [left side of engine] and the shaft could have broke and the gear is jamming the cam shaft. seeing you have most of the tractor apart i would pull the engine out and pull the pan if nothing check in the bell housing and at the hyd. pump on the left also your started nose cone could have broke and got in to the clutch housing
[Reply]   [No Email]
marloweg
02-17-2013 20:15:37
207.118.179.152
 Re: 44 partial lock up with head pulled off in reply to marloweg, 02-17-2013 19:34:57
also if and when you pull the motor under the front of the motor where it bolts down there are shims MAKE SURE YOU DO NOT MIX THEM UP and they MUST go back in the way they came out
[Reply]  [No Email]
mlansing7836
02-20-2013 18:34:34
68.169.243.102
 Re: 44 partial lock up with head pulled off in reply to marloweg, 02-17-2013 20:15:37
I purchased a 44 that was assumed locked up. Tried pulling it and tires drug as well. I pulled the start off and found some chips in the rear, found out a small piece was wedged between the flywheel and the bellhousing.
I would check that, if would be loose and hit hard in my case as well.
Matt
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
