price check for MH44
OldMoIron
Would be a good price on a 1949 MH44 with 277 newer paint , new front tires, hard 13.6 rears, and new head. I have one need to sell. thanks
if it has a 277 then it should be a 44 special a straight 44 had a 260 so it's ether a special or it been repowered
if its a 49 it cant be a special. also a special is longer and has a different platform. dont matter if it has a 277 in it.
and a special has the heavy cast front hubs, 44's have the light rims that bolt on like a car.
In the ad section on this site the prices vary from 900 dollars all the way up almost 4000 dollars.If the unit runs good and is in decent condition start your asking price mid range.Makeing sure that you are able to get out of it what you have invested.As for the engine.The 277 will bolt into a standard 44.The 260 engine can be fitted with 4 inch piston kits.Continental engines also made a 4-1/16 piston and liner kit that would fit in the H-260 and the H-277.I know this because the engine for my farthers standard 44 has the 4-1/16 piston kits in it.
