mf65 fuel lift pump
steve f
New User
I bought a mf 65 and the fuel lift pump needs to be replaced--old one is missing and the serial number plate is missing. The web says a 3637338m91 may be the replacement for serial numbers before 29f4249--without the serial number or the pump--how do I tell what to buy
To my knowledge, there was only two lift pumps fitted to the MF 65 or 765 diesel tractors. One with, and one without a sediment bowl.
Both types were fitted to the 192 and 203 Perkins engines.
Has your existing pump got a sediment bowl fitted? If so, the part number you quoted should be the right pump. Later updated number is 4222 452M91.
If not, the Perkins pump number is 2641328, or new Agco number is 4222 107M91.
Hope this helps,
Evan.
Hi,
Just to add a little here. My European Bepco book shows only one type of pump fitted to the 65 and 765 tractors with the 165 etc in between. The engines covered are the A4.192, A4.203 and AD4.203.
Bepco reference is 30/100-5 with the OEM numbers as 4222 452M91/ULPK0009.
The repair kit is 30/101-5. OEM 4222 110M91/ULPR0004.
DavidP, South Wales
