Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Massey Fergerson 1085
hymie2lt
02-11-2013 06:24:59
Hi Len Does your 1085 have the shifters mounted near the steering wheel? and the shifter is in up position when it slips out? If it does it is like our 1100 Massey. We had this problem...found out a mouse had built a nest under the linkages below the shifter. Open the small panel on the floor in front of the steering column, you may have an accelerator pedal down there too. check under the linkages for any dirt and gunk that will not allow the shifter to go completely into gear. If this is not it you may have worn shifter forks or detents. Wayne
Len Calneggia
02-12-2013 05:01:07
 Re: Massey Fergerson 1085 in reply to hymie2lt, 02-11-2013 06:24:59
Thank you Waynr for your reply. My 1085 has gear shift near steering and has been modified with an ectended bar. I will do as you suggest and thanks again.
Kind Regards
Len c
Len Calneggia
02-14-2013 22:51:32
 Re: Massey Fergerson 1085 in reply to Len Calneggia, 02-12-2013 05:01:07
Now I can give you guys some info. My MF1085 clutch was slipping under load and the adjustment did not seem to be working. Turned out that the linkage attached to the shaft coming out of the cluth housing, which has a knob on the lever was touching hard up against the bell housing and not letting the cluth to fully engage. An agle grinder did the trick!!
Cheers
