| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: Massey Fergerson 1085
[Return to Forum]
| Author |
[Modern View]
| Len Calneggia
02-11-2013 00:40:21
124.148.83.24
My MF 1085 Sometimes jumps out of second gear (when in High range) Can anyone tell me if this is easily fixed? |
[Reply] [No Email] | |
| Robert Major
02-12-2013 17:35:11
216.81.17.23
Re: Massey Fergerson 1085 in reply to Len Calneggia, 02-11-2013 00:40:21
| Hi I Had an 1135 with the same shifters as this and that used to jump out or try and put 2 gears together or not return to neutral the odd time. it could be that the pin holes in the linkages are worn and the lever hits the stop before it's properly in gear. I had to mess with the adjustments on the linkages until I hit the sweet spot, it really needed the linkages re built but I didn't have the time to do it and it got sold on shortly after. It only takes a few thou of an " wear to give a problem over the distance of the linkages. If that is your problem I've seen guys file the slot so the lever moves further to as a temporary fix . Regards Robert |
| len Calneggia
02-14-2013 22:45:28
124.148.238.244
Re: Massey Fergerson 1085 in reply to Robert Major, 02-12-2013 17:35:11
| Thanks Bob I will look at that possibility too. This forum is great where are you from I am from Margaret River Western Australia and use my MF maily for moving hay bales as I have a F/E loader fitted which is another story!! Have a small Beef cattle farm but earn most of my living off farm. |
| Robert Major
02-15-2013 17:47:54
216.81.17.138
Re: Massey Fergerson 1085 in reply to len Calneggia, 02-14-2013 22:45:28
| Hi I'm in Manitoba Canada. Yes these forums are great and very useful. I fix tractors for a living and come on to pass around stuff I have seen over the years, Also if something comes in the shop I've never seen before, I'll come on the forums or you tube and see whats around for info and the trade tricks. It can be amazing what you can learn! saved $300 on ford f250 super duty power door locks the other day. I found a repair it your self video so i didn't have to buy new that in 6 months would have failed like mine :). Good luck with the 1085 I hope it's nothing more than a simple fix. Regards Robert |
| hymie2lt
02-11-2013 06:24:59
204.237.119.236
| Hi Len Does your 1085 have the shifters mounted near the steering wheel? and the shifter is in up position when it slips out? If it does it is like our 1100 Massey. We had this problem...found out a mouse had built a nest under the linkages below the shifter. Open the small panel on the floor in front of the steering column, you may have an accelerator pedal down there too. check under the linkages for any dirt and gunk that will not allow the shifter to go completely into gear. If this is not it you may have worn shifter forks or detents. Wayne |
| Len Calneggia
02-12-2013 05:01:07
124.150.49.157
Re: Massey Fergerson 1085 in reply to hymie2lt, 02-11-2013 06:24:59
| Thank you Waynr for your reply. My 1085 has gear shift near steering and has been modified with an ectended bar. I will do as you suggest and thanks again. Kind Regards Len c |
| Len Calneggia
02-14-2013 22:51:32
124.148.238.244
Re: Massey Fergerson 1085 in reply to Len Calneggia, 02-12-2013 05:01:07
| Now I can give you guys some info. My MF1085 clutch was slipping under load and the adjustment did not seem to be working. Turned out that the linkage attached to the shaft coming out of the cluth housing, which has a knob on the lever was touching hard up against the bell housing and not letting the cluth to fully engage. An agle grinder did the trick!! Cheers |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
