TractorLinks.com
Show Parts for Model:
Re: Massey 50 pto slipping
TLZ
02-10-2013 20:15:14
I just read an older post about a weep hole being plugged and yes mine on my massey 50 was plugged. Likely accounted for some of the oil on the clutches.
DavidP, South Wales
02-11-2013 11:23:50
 Re: Massey 50 pto slipping in reply to TLZ, 02-10-2013 20:15:14
Hi,
Using a flashlight examine the clutch cover closely for any sign of oil. Normally when oil is present it can be found on all parts. As has been said, make sure that the adjustment is correct first and that no release pressure remains on the PTO plate when in use.
DavidP, South Wales
mike paulson
02-11-2013 04:14:08
yea no that its unplugged put a pan under there after use to determine how much is really leaking, and how much your adding. you can go a while before a split or maybe not. make sure everything is in proper adjustment on the 2 stage clutch, just follow the manual. it can be done from underneath thru the plate hole with alittle patience.
