Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Oil and hydraulic fluids for 67 MF135
02-08-2013 07:52:06
i used shell rotella 15w40 in the motor as it still has the zinc additive, for long motor life.
but as tom said,
buy your trans/hyd fluid from the dealer, you do not want to buy some cheap off the wall oil and ruin your hyd system or trans.
does your model have a trans/hyd sump filter that can be changed.
02-08-2013 07:55:20
 Re: Oil and hydraulic fluids for 67 MF135 in reply to maxwell99, 02-08-2013 07:52:06
Thanks - not sure about the trans/hyd sump filter - location? I have the Deluxe 135 model with Z145 Cont. gas engine.
Tom from Buckeye Lake
02-08-2013 08:56:49
 Re: Oil and hydraulic fluids for 67 MF135 in reply to DW1973, 02-08-2013 07:55:20
Your filter is in the belly of the beast. If you DO NOT have IPTO, remove left cover with the pto lever to get to filter. If you have IPTO, lift cover must come off.
By the way, there are two drain plugs for Hyd oil to get it all out.
