1)Drain the oil from the trans.
2) Take off the seat.
3) Remove the lift arms.
4) Remove the top cover, you will need a lift or help.
5) Remove pump Dowel Pins ( one each side )
6) Remove differential drive coupling
7) Disconnect pump drive coupling and lift straight out.
I have 3 pumps in stock if you need one.
802-782-2409
