MF 1085 three point problem
lemroy
On my 1085 the three point lift will work without a load but when I hook it up to a mower, It will not lift it. I have had both hyd pumps worked on. The other hyds work just fine. Any help will be appreciated. Roy
Roy
I"ve said this before and will say it again. Once you replace the 3pt pressure relief spring your problems will be solved. Been there done that on a 1080.
Merle
