TractorLinks.com
Show Parts for Model:
Re: MF35 with worn 23C
Tony in Mass.
01-31-2013 18:41:39
Please start your overhaul soon... my completely rebuilt one needs a freind.. misery loves company??
Phil Tibbetts
02-01-2013 06:07:14
 Re: MF35 with worn 23C in reply to Tony in Mass., 01-31-2013 18:41:39
Hey Toni can you run that up to Maine this spring for mosquito season?
Tony in Mass.
02-01-2013 16:13:35
 Re: MF35 with worn 23C in reply to Phil Tibbetts, 02-01-2013 06:07:14
Boy have I got a deal for you..... see you in April!
Masseynut(Australia)
02-01-2013 02:07:49
My eyes are stinging and I can't find my breath just looking at Tony's pics! It's definitely a good example of a "well worn and worn well" engine. Luckily yours sounds like it has only worn compression rings, allowing the combustion gases down into the sump. The oil control rings must still be doing their job, or else it would it would be causing "global warming" like Tony's Rolls Royce!! I'm not big on additives in the oil, as nothing substitutes an engine in good condition, and nothing "in a can" can replace worn engine parts. So I would suggest running it on, say a 20w50 oil and keeping your fingers crossed. You may get a slight decrease in oil consumption and the engine should go for many more years, as long as it's not worked hard, or driven "like you hate it". These old English engines are very forgiving animals, as Tony's proves right here.
When your ready to rebuild, post a message and I'll give you details on how to make your 23C engine, notorious for having a reputation as a "bad" starter, fire up like a 3 cylinder Perk, good luck, Evan.
OzMF35
02-03-2013 03:03:43
 Re: MF35 with worn 23C in reply to Masseynut(Australia), 02-01-2013 02:07:49
Thanks Masseynut. I'm an Aussie as well - down Vic - West Gippsland way. Yeah I realise there's nothing in a can that will fix it but am hoping to stretch it out a little longer before the inevitable.
I put some fresh 20w50 oil in it and a bottle of the Lucas oil stabiliser and will see how it goes. I slashed a few acres with it today and think the blow by was a little less obvious - but still excessive of course.
I'll probably try and rebuild it at some stage in the next 12mths so will be sure to get in touch when I do. I'm hoping to do some hay cutting and baling with it eventually. In the meantime the tin work may get a fresh coat of red.
02-03-2013 04:25:22
 Re: MF35 with worn 23C in reply to OzMF35, 02-03-2013 03:03:43
They are a great tractor, and apart from very, very few "built in" problems, this tractor will still be going when you and I are both gone! keep in touch, Evan
OzMF35
03-13-2013 15:50:19
 Re: MF35 with worn 23C in reply to Masseynut(Australia), 02-03-2013 04:25:22
Hey Masseynut, appears I cant pm you for some reason?
I'm about to paint the tin work on my 35, wanted to ask if you know anything about paint for these things? I can get the Bare-co tractor and implement enamel from my local dealer in MF Red and was wondering if its ok? Its a functional tractor - not a show pony, but I want to do a reasonable job.
