Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: MF 165 or 265
Masseynut(Australia)
01-30-2013 16:24:40
To add to the other contributors here, if your looking at a 165, the later models with oil immersed wet brakes were a far better option than the earlier models, that sometimes had troublesome dry disc brakes. Evan.
Dieseltech
01-30-2013 21:23:52
 Re: MF 165 or 265 in reply to Masseynut(Australia), 01-30-2013 16:24:40
MF 100 series US tractors, I have never seen wet brakes on either early or late models. 200 series did have wet brakes on late models. Sounds like UK got the better wet brakes before US did. My early 165 has same brake 65 did, brothers late 165 has dry brakes too, but plates are larger diameter than early models.
Jason S.
01-31-2013 08:28:24
 Re: MF 165 or 265 in reply to Dieseltech, 01-30-2013 21:23:52
I wish the US versions did have the wet brakes. My 175 is a 1974 model and it's got the dry brakes but I plan on doing the wet brake conversion on it.As far as the 165, I grew up with one and it was a 1965 model. I never did really notice the vibration from the engine. I can tell you that the hour meter quit in 1980 and it had 7200 hours on it then and we used it daily until 1992 when we got a 253. I'd say that tractor had over 9000 hours on it and it is still running to this day. All that was ever done to it was two waterpumps,clutch,front axle pin, and brakes. You cant go wrong with either tractor although the 265 has a better steering system from what I can remember and it you are going to use a loader the 265 would be the better tractor for a loader.
01-31-2013 02:22:51
Jez, you blokes did get the rough end of the pineapple! The English built models had wet brakes from 71' thru till the last model in 79'. They were referred to as the "upgraded" models. All dry brake models up until then, had the same diameter discs as the 65's.
When did the last of the 165's run to in the US?
Dieseltech
01-31-2013 04:58:30
 Re: MF 165 or 265 in reply to Masseynut(Australia), 01-31-2013 02:22:51
The last 165s I remember being sold when working at MF dealer was 1973, but may have been 1974. Recall several 200 series sold in 1975, even they had dry brakes, but larger diameter, still 2 discs. Not sure what year multi disc wet brakes were installed.
