| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: Re: clutch doesn't stop pto at all on my mf 135
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| zach hulbert
01-29-2013 08:04:21
70.100.226.176
I cant engage the pto while the tractor is running have to turn the tractor off and then engage it. So what would be the problem then and how to adjust the clutch pedal |
| DavidP, South Wales
01-29-2013 12:43:40
2.101.115.152
Re: clutch doesn't stop pto at all on my mf 135 in reply to zach hulbert, 01-29-2013 08:04:21
|  Hi Zach, Failure to engage the PTO is normally down to bad adjustment. First of all try and understand how the clutch operates. Remove the inspection cover from under the clutch housing. Turn the engine until you can see one of three adjusting screws. There should be a gap above the screw head of around 080". Have an assistant press the clutch pedal in the first stage only. At the ond of the first stage the screw head should be in contact with the PTO pressure plate. Have the pedal pressed to the floor. You should see the pressure plate move rearwards. Correct free pedal adjustment is approximately 3/8" clearance where the external clutch arm strikes the case or makes contact with the underside of the foot bar. The unladen PTO should stop turning when the pedal has approximately one inch of travel remaining. These are not exact figures as every tractor is different due to wear etc. When you understand how the unit works you may be able to see if there is a difference in the operation of one of the release levers for example. My compatriot Fergie Bach has suggested the use of one hacksaw blade as a gauge. It is more likely that you will need two with the teeth ground off. Check the clearances that you have. I suspect that they will be in excess of the 80 to 90 thou. Using good fitting openended 1/2" AF spanners slacken the locknut just enough to turn the screw to give the correct gap. Ensure that all three are the same. When finished observe the operation through the inspection aperture. Pedal adjustment can now be carried out as above. If you do not have a positive 'stop' of the PTO it may be necessary to reduce the clearances slightly. You MUST have dis-engagement when the pedal is approximately one inch from the end of travel for safety reasons. Please let us know how you get on. DavidP, South Wales |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
